How do you keep Edge 500 going for 20hrs +
Moegery
Hi,
I did the Trans Baviaans and charged it while using it.  The trick is to use a cable that does not have data transferring capabilities.  Only has a positive and negative wire in the usb cable.
Hi,
Easy as pie.  Made all my cables to work the Garmin in situ.
Use a tester to determine which wire is which and then cut all the wires except the + and -.  Do not go by colour as some cables use different colours.  Shrink seal when you are finished.
