Fox Float Fluid
The MTBer
Hi guys!
I am desperately looking for 5ml fox float fluid, mine accidentally squirted out when I deflated my fork.
I am doing a race this weekend and no shop is able to help me (i should buy a R350 service kit for a rear shox to get it) can anyone help me out?
Hi guys!
You can get the same fluid from a motorbike store at 50% of the Fox branded fluid. I think (but do a check) Fox uses 5 weight.
The blue float fluid on the air piston is thick.  Use gear box oil (80 to 90 wt).  See if a garage near you will give you some.  I am in Midrand if you want to collect but I am sure you can get closer to Centurion.
Thanks. The other question is synthetic vs regular gear oil? I know with the lowers you need suspension spesific oil.
