SRAM Red 10 sp & 11sp eTap Upgrade kit1
BMCfan
Hi Tech Guru's
I'm currently using SRAM Red 10sp and was thinking of upgrading to eTap
Two questions
1) Will i be able to put a 11sp cluster on the current 10sp hub?
2) Will the 10sp crankset work or will i need to replace it??
3) Anything else i should be worried about?
Thanks in advance for your input!
I'll have a look at the model tonight, but i'm using Mavic Ksyrium something something with a the standard hub that came with the rim. Hold thumbs its compatible :-)
