Which brake adapter
Titanfan
You more than likely have an adapter on their currently with the 160mm rotor. Take a pic or tell us the part number on it...if there is one!
The SM-MA-F180P/P2 is the common adapter for shimano calipers (for 180mm rotors) and I assume tektro and the likes too
Hi All
I would like to fit a 180mm rotor at the back.
I will be using the slate T4 caliper.
My question is which adapter should I use.
Titanfan - what are your thoughts of the Slate T4s? How long have you been using them for?
