Fox fluid / grease
JTK
Hi guys,
where can I find some fox fluid (the heavy stuff) and some suspension grease today still in the Midrand/Centurion area?
I realise that the fox fluid is around 90w gear oil but I am worried about rubbers and seals if I get the incorrect stuff. The suspension grease the same thing... Worried about seals etc...
ps. I assume good old lithium grease will work fine for the wipers? May have to chance my arm on 90w. tried using normal 10w on the foam rings but I can see the film on the stanchions. recipe for a mud pie that!
actually want some gold as well.. have a kashima that needs servicing... :D
btw.. where can you get a bottle of gold?
