Cannondale BB30 crank HELP
Furbz
So i just received my early Xmas present to myself - the new Sram GX 1x12 groupset
unfortunately i almost immediately ran into trouble.
the spindle on the BB30 crank i ordered is too short for my BB30 cannondale scalpel 2014 - which is nothing short of maddening.
this spindle is 86 or 88mm on the crank but needs to be 100mm when i measure the width of my BB.
worse still, with this crank it looks like the spindle is not removable. so i cannot just change the spindle.
i cannot return the crank either as it was imported.
Sram do a specific carbon crank for cannondale at a whopping R7500! or you can buy the cannondale crank at R12500!
anyone know a cost effecting 1x crank i can buy? - i do not need the best of the best. i just need something that will work
HELP!
I've got a SRAM S2210 (OEM) carbon crankset lying about.  Its in excellent condition as I removed it from my Scalpel when I changed over to the Cannondale Hollowgram cranks. The spider is removable so you can fit 2x10  or a direct mount 1x11 chainring. From what i remember it is basically an XO quality crankset, but only branded with the SRAM decals.
If you interested interested drop me a PM.
Hi Furbs
I have a SRAM X1 BB30 Carbon crank, I used on my previous Scalpel (2015)
It requires 76 bcd chainrings, I think it has a 34 on at the moment..
You can use your existing bearings etc....
All good condition
Let me know if you're interested...
What about your original crank with a new wide narrow chain ring?
the bike was my fathers before and spec'd with a clavicular carbon SRM which he is keeping. so no original crank sadly
PM sent
Hi Furbs
All good condition
PM sent
thanks guys
You sure the spindle can’t be removed? Reason being is, i had a cannondale hollowgram si crank where i could remove the spindle.
I might just have a spindle for you thats longer than 88. But ill only know on saturday
Edit. Crappy spelling
Furbs i may have a truvativ 2x11 spider also came off a scalpel.
As for spindle iam sure i have a spare one off my road bike which is about 100mm i think
If you dont come rite and prepared to wait until the new year pop me a msg on whatsapp.
