Derailleur B screw problem
Kian Kruger
You can simply replace the B screw with a longer one. However, if not enough, you either need to replace your derailleur (i.e. long cage) or use a Wolftooth Goatlink.
Or screw the B-Tension screw in from the other side. ie so that the head of the screw pushes against the Hanger. It makes it a bit harder to tune the setup, but once it's done you don't need to touch it again.eead17e0d06837b02e90912544c5d2df.jpg
This.
