Tyre pressure for Enduros
Trail Ninja
Hi Guys
Can the enduro and downhill junkies just please tap into this question quick
General preferred tyre pressure when riding enduro???
I have ARC27 29er wheelset with 27mm inner width
Ride Onza Ibex 2.4 front and Specialized Purgatory 2.3 rear
I weight 72kg and have 120mm travel front and 110mm travel rear (Pyga OneTen29)
I know terrain obviously plays a huge role.......but for those doing Dirtopia enduros or generally enduro type riding...what should my pressures be?
Or at least what should it be with some different terrain aspects such as rock, gravel, loamy forest etc.?
Cheerz
Hi Guys
Cheerz
At your weight and with those wheels 25psi rear and 22psi front would be the safe bet. Drop 1 or 2 psi lower if you feel you're lacking grip and don't mind risking a dinged rim.
Yip, add a foam insert to help with that (Foamo, Cush Core, Huck Norris etc etc etc)
Also for CT trails, be aware of the strength of side walls on your tyres....we have surprisingly sharp rock conditions down here...exacerbated by the dry conditions
I wish I could find Cush Core in SA.
I generally ride 1.7bar (25 psi) when going out in Tygerberg or so on, but this includes some flatter, less gnarley trails as well
My sidewalls are pretty bomb proof so not too worried there
Will give it a go at 1.6 bar and see
Cool
Cool
You want that front tyre 10-15% softer than the rear for extra traction. The rear wheel is the one that takes majority of the abuse, so run that one harder. Rear tyre also contributes more to rolling resistance, so the higher pressure will help there too.
Weight: 69/70kg
Bike: Enduro 29er
Wheels: Roval Traverse SL 30mm ID
Front: Butcher 2.6, Grid, 20psi
Rear: Ground Control 2.3, Grid, 24psi
Slammed the front on my last ride so have upped front pressure to 20psi from 18.
