SLX brake leaver dripping
phenning
My SLX barkes have recently been getting soft. so i reblead them but it did not improve mutch.
i now noticed a puddle of fluid leaking out onto the leaver.
is this the end of the brakes or is there something to be done
I had the same proble at wine 2 whale last years.Did the first day with no back brakes.Had to replace it.Seal on the inside of brakes lever was leaking.
I still have the slx left lever if thats what you need.
There is a Post somewhere on this forum that has Rebuild of XT levers, the SLX levers are the same essentially.
I would give it a try first, If your not skilled in DIY your only option remaining is replacement.
If it's leaking, either the seals and / or the bladder have failed or there's corrosion in the bore. Either way, there's not much you can do about it aside from sourcing a rebuild kit from overseas - our local agents don't bring in spares smaller than a complete lever assembly.
