Morning all,
I need to bleed my Hayes Sole disk brakes. Do I need to get hold of the manufacturer's bleed kit or is there a DIY bleed kit that I can build that will do the same job at a fraction of the price?
Lastly, how do I go about this? I'm pretty handy, just need a direction to be pointed in.
Guest Big H
I got the Hope belled kit that uses pressure form the tyre. It attached to the Hydraulic fluid reservoir and "reverse" bleeds. It works well and there will be no oil spots on your pristine paving. Assuming you ride a Toyota and not a Ford or Alfa Romeo.
