Lefty hubs
JacBrand
Nope not as far as I know. Left 2.0 takes a 60mm wide hub (between flanges while the older Lefty takes a 50mm (between flanges) hub.
A 50mm wide hub can be spaced with adaptor kit to work on Lefty 2.0 but a 60mm hub is not backwards compatible. I could be wrong
You can use a 1.0 hub with a 2.0 fork, but you'll need a R 1.5k + adapter for the brake and a redish. I don't think the 2.0 hubs are backwards compatible though.
