Help needed with checking dimensions specs
JaQ
Greeting,
I need knowledge in regards if the following components will be compatible with my Giant Stance 2 27.5 2015.
https://www.chainreactioncycles.com/za/en/shimano-slx-m7000-1x11-drivetrain-groupset/rp-prod148625
The link above is the groupset I am looking at. My bike has an FSA bottom bracket bb-cfm92 24mm Alivio derailleur 3x9.
So the question is will my current bottom bracket be compatible or do I need to get the following bottom bracket that the link states are compatible; BB-MT800/BB-MT800-PA?
Thank you in advance.
have you looked at getting 1x12?
not dissing the shimano but you can get a SRAM groupset, with LOCAL support for RR5800.
https://bike-addict.co.za/products/sram-nx-eagle-groupset?variant=12663861739604
I'm sure you can get a better price somewhere.
or just get the upgrade kit, keep your current crank and fit a single chainring.
https://bike-addict.co.za/collections/groupset/products/sram-nx-eagle-upgrade-kit
it will be a moerse ugrade from the 3x9
If I go the SRAM route which personally I like more. Will I not need to replace the fee hub on the rear as a heared that it does not fit nicely the  SRAM cassette on a shimano hub?
the NX cassette fits on the standard hub, no XD driver needed
