Squeaky Silverback rear suspension.
M Hickley
Hi.
Need some advice please. I bought a new Silverback Sido. The rear suspension starter squeaking after 5 rides. I suspect that it might be the tophat bushes. Is it wise to use something like WD40 on them. I already checked the torque settings and everything is fine. I also used copper compound on the seatpost when I assembled it.
If it's the top linkage above the rear tire you might have the same problem I had.
There are 4 washers in the linkage which have been pinched when they were installed. When I replaced mine the squeking was gone.
It's a cheap fix, R20 per washer
