Accelerator Concept SL Road bike
George le
Does anyone out there have any idea who manufacturers this bikes having a problem with with the integrated seat tube can only insert the seatpost inline with the top tube will not go further down looks like a piece of carbon on the inside prevents it from sliding futher down wondering if it was designed that way the carbon seat tube has a thick carbon wall but anyone with info in this bike it would be appreciated.
George, looking at the position of the stem and the seat height, is not a question of the frame is much too big for the individual to whom you are looking to adjust various settings?
its a Chinese frame, likely Hong-fu or similar
The reason you cant get the seat-post further into the frame is because its an integrated seat post and it needs a seat collar that slips over the seat tube extension once you have cut the mast to the correct length....
What DnD said.
They left mine at full length as i needed the extra length, plus a bit. If you don't come right with Customized Cycling on the links above i can PM you a number for them.
