The KICKR SNAP has a through axle adapter kit you can use.
This is ONLY limited to 142 and not BOOST.
Our team is experts on the KICKR SNAP an Through Axles - Please give them a call on 0876541940 or support@wahoofitness.co.za and they will be able to answer.
Sean or Dylan your go to guys.
Your local Wahooligan
Christian
I have a Cycleops Hammer H2 it came with two through axle end caps and two 9mm quick release end caps, one simply replaces the 9mm quick release end caps with the 12mm through axle through axle caps and the frame fits straight on. They just screw on one or off. I would assume the wahoo would follow a similar process. I have a Vipa frame like yours and have had no issues.
Edited by warick_wrx
  • 1 year later...
Does anyone know where I can get a 168mm rear Thru Axle adapter for a Merida Scultura 6000 to use on a wheel-on trainer?
Seems most of the one's being sold are 142mm
