Hi Folks
As per the title, does anyone know where i can get crank boots that would fit on a Lyne Pulse crankset?
I've seen some of our online stores got but I'm reluctant to order because I'm worried it wont fit.
Or should i just go to the local LBS with bike and try out the options?
If your Lyne pulse Crank is the alloy version you will need the small boots
If the carbon it's the medium sized boots.
Your lbs can definitely tell which size is appropriate
