I looked (for the first time ever) on my Bianchi Oltre the spacing on the front wheel ... so the spacing between the tyre and the brake caliper is about 1mm. Does that sound correct? Can it be adjusted? Or am I missing something. TIA
That looks super close. Take the wheel off and check that the dropouts on the fork haven’t worn down.
But the front dropouts cant be replaced if thats the case?
Running 25mm Conti’s. Same Tyre that I have been running for the last 12 months on the same bike. Just replaced the tubes a day or two ago as I had a double flat after traveling to the Western Cape.
