Does anyone know if such a tool is available . DT Swiss have a tool but can’t find anything for a Hope hub. I broke a pawl spring and it damaged the ratchet ring. The hub is more than 2 years old so out of warranty .
The free hub no longer engages on the forward pedal stroke
Last resort would be a hub replacement ????
Is it unusable?
I've never heard of someone removing the ring , doesn't influence bearing removal and they're so reliable that they never wear out.
Post some pics ?
  On 6/6/2021 at 1:25 PM, BaGearA said:
Is it unusable?
Post some pics ?
Expand
Yes . I will post some. Also though Hope was bullet proof. 8900 km on hub
There is a guy in the cape that upgrades Kickrs that has a tool that removes the ring, its basically a hardened star tool, Google Kickr  upgrade, you will find him on Facebook. I have a ratchet ring I had made for the kickr, basically 26mm with 1mm pitch
Edited by Dexter-morgan
My ratchet ring came loose all on its own after LBS replaced wheel and freehub bearings and didn't instal properly which made for a long walk....although that's a Novatec hub. I'll forgive them as I've done something similar and they are Joburgs #1 LBS.
Edited by love2fly
Expand
what does the trainer have to do with his hub being damaged ? that trainer mos has its own freewheel that interfaces with a cassette ?
Expand
When I upgraded the old "noisy" type to the silent type, you have to exchange the Free-hub outer that sits in the Flywheel, that little ratchet thingy looks the same as the DT-Swiss units.
