4 minutes ago, DieselnDust said:
sounds like you need a edge 1030 or 1030+ 2 columns with 5 rows each max.
Ā
If you want a GPS bike computer that can route for you then the Sigma Rox 12.0 is the unit you want.
Sadly they have been of stock for about a year :(
Don't need 5 rows. Just want 3 rows 2 columns and equally sized data fields....edge 530 can't do it.... šŸ˜€
  • Replies 42
What about layout called 7A?
It has 2 columns of 3 with a larger view as the 7th.
The 7th larger is the issue. I just want 6 equal blocks like my Bryton....
42 minutes ago, DieselnDust said:
If you can load the Komoot app it does routing. I haven't tried loading it on my 1030 because i'm afraid it will brick itself
Will look into that, thanks.
Do you want to swap your non-6 screen Garmin for a Lezyne Mega C which is capable of showing 6 screens? It even has a Garmin 1/4 mount.
Edited by Frosty
šŸ˜€ no thanks. Its only a couple of months old and got it for pretty much nothing....I'll carry on with using HR as my main value and now and then see the others...
