  • Replies 53
They were both bent! Have had the same rotors for 4 years and they are holding out. This includes a season of downhill racing in the states.
four years?!!!!!!!!!! wow, you know how to stretch things! time for a new set. what brakes you running?*
*sorry if this is posted elsewhere on the thread.
Are they worn after that kind of use. I have just checked and mine are actually thinner on the edges where the pads run. They are also pretty old. I find my pads dont wear evenly even if they are set properly.
Use a shifting spanner. Job-specific tools are great but I prefer generic tools. I've fixed a couple of disks using just a shifting spanner. I don't even take the wheel out of the bike' date=' but you do need?a stand so you canj spin the wheel and look at the disk head-on.
I am with JB on this one. The disk is mechanical and a little savvy and patients get this running perfectly true. My blades were out of kilter from day one. So much so that the wheel couldn't run a complete rotation without rubbing at least twice. The shifting (Vrystaat no 13) worked perfectly. Problem with the stove method is that it stuffs the tempering of the blade. And I know there are going to be some wise cracks about the blade's tempering, but it was done with a reason and I personally rate brakes as safety devices. You don't tamper with the design.
Let me the wise crack to tell you about the blades tempering . Unless you heat the blade to +220F (it becomes this funny red color) you are wasting your time trying to change it's "tempered" properties , but if you do feel like changing it your stove plate will not really do the job .
