I have noticed a lot of the pro's riding with two ring drivetrain, obviously throwing off the granny. Do you actually buy it as is or is it something a bikeshop does for you? what would be the benefit of this?
You can do it yourself, I only have 2 rings on my XTR cranks, I never used granny so I got rid of it. You just unbolt it from the rest of the crankset.
You can do it yourself' date=' I only have 2 rings on my XTR cranks, I never used granny so I got rid of it. You just unbolt it from the rest of the crankset. [/quote']
Do you move the crank further inboard or just leave as is?
I took a spacer out from behind the BB on the drive side, so to answer your question yup you do. This way the chain does not drop as frequently.
Benefit? None I can think of besides that bit of weight it saves that is probably only valid for top pros and other wannabees ..........
I like the less shifting involved
You don't have to use the granny Wink
Then why have it on the bike?
xactly!
I  found i seldom use the granny. If I do then it's faster to hop off and walk. So I run a 44 x 29 set up.
 For an XTR you don't have to remove the spacer, but it does help as Racer says.
I have a 32 x34 at the moment. My mate at an engineering works is gonna make me a 29 tooth for the front though, then'll go back to 32 at the back.Big%20smile
