I'm using campy record rear derailer and chorus cranks with a dura ace chain and casette.
but i'm having problems with shifting, it slips a gear when i'm in my small chain ring.
what can I do to solve the problem?
alot of people have said that it's because i use shimano with campag and others say that it works better when you do it like that???
but i'm having problems with shifting' date=' it slips a gear when i'm in my small chain ring.
had the same problem and changed the shimano spacers between the gears on the cluster with campag spacers. problem solved.Tongue
what shifters are you using?
I use Campag Carbon record shifters and Rear derailleur' date=' Ultegra chain, BBB cassette and FSA Cranks.
not a dropped shift in 4 years
using campag chorus carbon shifters
thanks, will definitely try it!!
I presume I can just order campag spacers from any bike shop? I wont need to buy the whole casette?
Good luck with that. I doubt you will find spare spacers anywhere.
Or try get hold of an old shot cassette and rip that apart. It'll prob be easier than buying just the spacers.
Maybe one or two of the hubbers have something that can help you.
You can always order a shiftmate from overseas' date=' not too expensive:
http://jtekengineering.com/shiftmate.htm
I also saw an article somewhere where the cable to the rear der was fixed above the bolt instead of below(or vice versa).
Ok, found the article:
http://www.velonews.com/article/73404
I had a look on these links, thanks alot they were of some help!
you don't know if these shiftmates are available in SA?
