Hey all,
I have just got a SRM, it a great unit BUT.......
how do I know if the battery in the crank disc has gone flat or is on its way to going flat, I am having huge problems with picking up a power reading.
the pick up is places correctly and does not move during a ride, I will sometimes get it picking up during an off set test, but then during the ride there is nothing.
I know the unit is due for a service but would like to know if it is the battery first
any help please.....
I had a similar problem with mine - basically very erratic power
reading during a ride and then eventually is stopped picking up (even
though sometimes it would work while dling offset)
If it is not cable (I tried a new wiring kit first) then it is almost certainly battery, especially if it is due a change.
Good luck - mine has been 100% since I had both batteries changed.
BikeMax2008-12-08 01:55:45
It sounds like the battery! Mine was doing exactly the same. I tried a different cable kit with no luck and then I sent both the cranks and the unit away for battery replacement. Now everything is working 100%
Contact Activeworx on (011) 234 1303
