I need some help in cassette ratio's.
I recently purchased two 11-32 cassettes - my bike is currently fitted with an 11-34.
How big will the difference be, especially on hill climbs ? Is it worth worrying about?
Cheers
No need to worry! If you need a 34-granny combination you're probably better of pushing anyway. A further plus is the fact that the jump between gears are less noticable with the 11-32!
Nothing to worry about. You can climb stairs with a granny and a 32.
I made myself a little spreadsheet to see exactly what combination of crank/cassette gives what speed at what cadence.
Cassette tooth count:
aqas
283234
252830
222426
202123
181820
161617
141415
121213
111111
Typical crank combinations:
4844
3632
2622
The gear ratio is simply the crank teeth count divided by the cassette gear teeth count.
To work out the typical speed at a given cadence:
cadence x wheel circ (i use 2.068m) x gear ratio x 60 / 1000
BigGuy2009-01-07 07:54:30
11-34 is good for starting out or perhaps mixing with the Double Chain ring option some MTB'ers are going for.
If however you have a decent level of cycle fitness the 11-32 is the right cassette to have, the 34 tooth granny gear selection is not worth the speed you'll get, as Fulmenicius said you can push faster.
I must say when starting out I pondered switching over to the 11-34 tooth option on almost every super steep climb. Now I like my 32 tooth and tend to use it and the small chainring very infrequently.
