Hi
What is the preferred puncture prevention option? The hard tape on the inside of the tire or the gel that is pumped into the tube?
use both.
No dont. It will be as heavy as hell. And that liner will cause more problems. Listen to me. Go tubeless.
of course tubeless is the best option, but if he's limiting himself to slime and liners, then i'd still say use both.
use both.
of course tubeless is the best option' date=' but if he's limiting himself to slime and liners, then i'd still say use both.
No. Thats like using two condoms at once. Just get a decent sealant then.Smile
My training wheels = Mavic Crossland (with worn bearings and free-hub) + Slime ultra tubes + half bottle slime + Kenda SB8. Front wheel = 2.6kg, rear = 2.8kg.  And I still get flats...
use both.
guess you know the story about using deep heat between two bits of latex?Wink
No. Please give us the details. I'm learning stuff here...
BigGuy2009-01-30 03:33:58
it's the only way to find out if a johnny gets broken before it's too late. one of you is gonna scream and go off looking for a cold water tap?at a rapid paceWink
