I was Just wondering if you tech boffins help me out here?
Which rear wheel would be faster over the ironman coarse in PE?
A normal deep section wheel like: Mavic cosmic carbone or Zipp 404?
or
Or a normal wheel with aero wheel covers (Making it a disc)?
Gawenator2009-03-24 08:17:23
I don't know about the aerodynamics, but I know that weight will make virtually no difference if you do not accelerate frequently and there are no hills.
  Quote
  Quote
...?normal wheel with aero wheel covers (Making it a disc)?
Where can I get hold of it locally? Bringing it in from Excel Sports will cost R2300 - not really a proposition!
This will not work at all the idea of a disc wheel is the stiffness and obviously aerodynamics i can not see these plastic covers doing the trick smiley5.gif
  Quote
Deep sections.
If the wind blows hard like its been then you wont be able to ride a disk.
Make sure you bring some shallow wheels ...just in case.
So you don't think a disk a option this year?
How has the weather been there lately?
With PE you never know till the morning of the race.Ride a disc if you have before and know what the handling is like.If not ride what you are used to.
A disc will always be faster - not sure about covers though.
PE wind is no problem for a disc. but as windblown says, you need to have used it before.
Only if you're a pansy should you stay away from a disc or if we get a Argus '09 wind blowing.
Having said that Zipp's 404 is pretty aero.
Weight no issue - you're loaded with gels, bars, bottles, wet shorts and shoes so 200-300g's makes no difference
