I bought some ODI lock-on grips in London, but for some unfathomable reason they don't come with the necessary bolts. And they're a funny (imperial) size. And I can't find them in SA, including at Topfast, who usually have anything bolt-y. smiley19.gif
Does anyone have any ideas? Or some bolts?
I have a set of spare bolts i ordered from CRC cause i lost some of mine and also had a problem. I will sell you mine as im still running foam grips and ive also lost 2 of the locks no so will have to order replacements for these aswell
Ngala24, where are you based?
OT, I do, but that sort of thing *shouldn't* be necessary. I will keep it in mind as a last resort.
Mampara - thanks, I'll check that out. I seem to recall that they're metric though.
Im in JHB, can arrange to have them posted to you. They still in the packaging, can send you a pick if you want ?
They came in with Hog's last order
Nope sorry lads, the Aerozine bolts don't work. I too have a set of ODI's with no bolts...
Droo - Olympic said they could order for me... You must have been bleak to get all the way back here and have no bolts. I know I was, but I only went as far as Kenilworth
Pissed me off no end when i tried to fit them last night, then remembered that you had the same issue with yours, which as I recall are still in the box...
Felt like a bit of a poephol, but I guess I should be used to that by now.
Im in JHB' date=' can arrange to have them posted to you. They still in the packaging, can send you a pick if you want ?They came in with Hog's last order
Thanks, will have a word with Olympic this arvi, and if they can't make a plan I'll take them. No need for a pic I reckon, if they work they work... will let you know tomorrow.
