Hi guys, I just got a new sram red group.
My problem: If the chain goes on the last and second last gear(9 and 10) ,when in the small blade in front, it goes against the front DR. It does not have the function like campag with a small clik to take up the front DR just a bit. I had it at a shop and no one can help.
You are not suppose to use that gear combination. By the time you get to the 3rd last gear you should have changed to the large front already.
Silly manfrog....
with sram red they have designed the front derailer so that there will be no derailer rub in any gear selection thanks to a wider cage on the derailer
so if the gears are set properly they will not need any trim adjustment and you could run in any gea rwithout having the annoying grating on the derailer
Guest colonel
I just got it fitted on my bike today aswell and I went and did that test quick and there is no rub so maybe the setting is wrong on yours?
yea exactly my thoughts as well if it is set up properly then te only rub you will get is the chain trying to jump up into the big ring thanks to the pick up's on the chainring
