Guest Big H
You should be able to buy new cones. ....... but if the hub cups are pitted like your cones your hubs are stuffed. use a ball point pen to trace over the bearing path of the hub cups where the bearings run. If the pen does not move smoothly your bearing cups are stuffed.
Have the hubs checked by a person who knows what they must look like before you take my word.
