i am 1.79 and bridge cycles in ct recommended a 56 to 58 depending on frame..
I'm 179cm with a 83cm inseam and ride a 54cm. Unless you have moer-of-a-long legs that doesn't sound right.
1.89 and a standard 54cm frame 120mm stem 175mm cranks BB/ top saddle - 810mm
I like an aggressive setup with a smaller frame for added stiffness etc, but not for the faint hearted I must admit Wink
58 is my "correct" size
slowtwitch2009-12-10 07:55:27
This is a guideline we use  and works well to give you a idea where to start ,once you have your size you need to try the bike as it could go up or down or stay the same . I ride a 59 Bianchi road frame and a 20? mtb.<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Eg : my inside leg is 90cm x .65 = 58.50cm thus a 59cm fits me well
For mtb take 58.50 cm ? 10cm = 48.50 divide this with 2.54 ( to convert to inches ) = 19.09 ?  thus I?m on a 20? mtb
As I said this is a guideline , and helps you know where to start.
To get a accurate inside leg measurement stand with no shoes on and back against the wall . take a spirit level and pull it up as far as you can into your grown , keeping it level take a tape measure and measure from the top of the level to the ground.
