Yesterday at the Emperors Race I was taken out by a slower short race rider. Net result is that both of my shifter levers are badly scratched.
My question is can only the lever part on a Campag Chorus Carbon 10sp be replaced, or do I have to buy the whole mechanism?
YETI5752010-02-08 08:48:52
You can replace only the lever.
The part numbers for the brake lever are (L/R) EC-CH547 and EC-CH448. Italian list price from Campag: EUR 76.40ea.
The shift levers are EC-CH428 and EC-CH429. Italian list price from Campag: EUR 17.60ea.
The thumb levers are EC-RE204 and EC-RE205. Italian list price from Campag: EUR 9.75ea.
The question is, can you get the spares through the local distributor for less than a new one from Total Cycling?
Edman2010-02-08 08:23:23
Chances are you can't.
I have a similar problem - have resorted to riding with them as scratched as they are, but at almost R3500 for the set, it doesn't look that bad...
A new set from Chris Willemse is R2800.00
Assumsing I can get the spares, the agents are the only one's with skills to replace the levers.
a bit off-topic but has anybody seen/heard of anybody converting the 10spd to 11spd? I know alot of people changed their 9spds to 10spds when it came out.
Ja' date=' I sold my Ultegra and bought Chorus, so now I have 11 speed......[/quote']
Ja slim Jan. I mean you can just replace the inside ratchet or something and it is upgraded.
I don't think it is possible.
Changing from 9 to 10 only required two small parts to be swapped on each lever. I believe the mechanism for 11sp is completely different and has almost no common parts with 10sp.
Edman - does that picture come with step by step installation instructions?
Sort of. You just put it back in in the order it's shown in the Campag spare parts diagram:
http://www.campagnolo.com/repository/documenti/en/Spares08_A_1007.pdf
The difficult part is holding all the springs in place while you're tightening it. That's explained here:
http://www.yellowjersey.org/ergo1.html
If you're just replacing the brake lever, you don't even need to bother taking out the other stuff. You just need to (carefully) remove the pin I circled in red. I did it using a vice, a block of wood with a hole and another pin/dowel/bolt. You could also use a gentle hammer instead of the vice.
If you're not keen on doing it yourself, Finish Line cycles can do it and I'm sure Northcliff can too.
