  • Replies 36
Could you please provide a link with the weight of a particular floating rotor you are talking about?
I dont have a particular link. I just recently upgraded my Shimano XT (full ss) to XT 2010 floating rotors, 180mm at the front.
Brilliant.
I'm using Ashima Airotors,light and work well.And cheap from CRC.
If they are light, they will bend easily. If they are heavy, they will hold true for longer.
You can't have your cake and eat it.
Alligator are the worse rotor ever had <_<
eating pads as hungry wolf :angry:
cheap and light and good heating dissipation : Formula
floating or not , similar weight and performances
pictured both 160mm
Formula rotors arent cheap!
i have floating hope rotors, bling and work well
Alligator iwave rotors worked very well for me too.
Formula :maybe here in Italy, with the right pusher i can find them cheap
i have Hope too ... on my R1 set not working as expected :(
now i have XX rotors : they work well
picture posted by DMC007 : shimano rotors are not floating
they have only a different spider and desing .
So enlighten me please, what is the difference between the two. I thought that any 2 piece rotor is considered as Floating. Allum centre.
the pretty much look the same but if you shake a floating rotor you hear a rattling sound. the outer and innter bits arent fixed...outer bit "floats"
the thing i can never understand - they say its to reduce the heat transfer to the calliper->oil
I thought it was so that the disc is always centre.
