Technically no......But I rode the other way round (campag on shim wheels) for years! Your shim cassette wont fit on the wheels. Take some shimano spacers and modify them to go on the campag freehub. Then use the normal campag sprockets and you should be fine....smileys/smiley4.gif
I have bought (from RulloBike) a Campy Euros 2006 Wheelset with Shimano Body... so Yep it can be done... there is also an aftermarket cassette available that will give you Shimano Shift Spacing on a Campy Cassette Body
I've ridden with both the wrong way round, Campy shifters on Shimano 10s cassette and Shimano Shifters on Campy 10s cassette, it works, it just doesn't work well. Shifting under power is a bit suspect but generally it works fine.
