Full Suspension Frames + Shock For Between R6000 & R6400
Hi Guys,
The team at Ness have an alloy full suspension XC frame (100mm travel) with either a Rock Shox Monarch 3.3 shock for approx R6400.00 or R6000 with the top of the line X-Fusion 02 RCX shock. Would anybody be interested? 120mm XC, 150mm AM and 180mm FR frames also available
Also, hard tails for under R1000 (1650grams)
651XC Pro Frame weight: 2.26kg X-Fusion RCX 270 grams Rock Shox Monarch 215 grams
A frame such as the one listed, are the spares easy to come by? Are the shocks a special length, difficult to find?
Hi Mojoman,
I'll stock replacement dropouts, headset and pivot bearing sets so that's covered. The shocks are very standard. The 651XC Pro uses a 165mm x 38mm size shock for instance. I'll have the other models shock sizes shortly.
