I know there are lots of topics about DIY lights but I need some clear advise on the topic before I waste my time.
I need to know if 2x MR16 size halogen 12v 20w 36deg 3000h ligth bulbs will be bright enough to do nigth rides with?
Under normal conditions 1 will be bright enough. Try and find the 10 degree version. Makes a much nicer light. This is a battery thirsty option but quick and nasty (and cheap) and very effective. I still use it for training as the added weight is only beneficial while training.
Edited by jacostrydom
Have you thought about using two LED Torches attached to your bars? Might be a whole lot easier. You can cheap it out and use duct tape :o or make up a simple mount using plumbing fittings to hold the torch. I bought an LED light for a few hundred rand and my neighbour pitched at one of our morning rides with a R50 torch attached to his bars with a R5 plumbing clip and outshone me by far. We ended up using his light to see whare we were going :)
Just a thought...
Just a thought...
Sorry... Only saw skollie's post after I posted mine. Are you able to buy just the handle bar bracket if you already have a torch?
Edited by Grebel
I ride with 3W MR16 LED downlighter bulbs connected to a 12V 1400mAh battery(guess 500g). I get more than 3hours of light and 1 light is good enough for night riding on mtb trails. I usually ride with one on the bar and another on the helmet. This light is about R200 more expensive than the halogen route, but it is much better.
