Hello all,
This strikes me as being a rather silly question - but reckon I've asked so many in the past - so why stop now! :P
I'm resurrecting an old frame in the next few months, that runs v-brakes but that can be converted to take disc.
My current frame is v-brake only, so I initially plan on carrying all across as is.
When time and budget allows - I'll upgrade to disc - and convert the first frame to a SS.
My v-brake wheelset will then go back to the SS.
Therefore, at some point - I'm going to have to buy/build a new wheelset.
My current wheels have treated me well over the past 4 years - but don't really want to take the rims through another wet, muddy winter...
I'm accordingly thinking of getting a new wheelset sooner, rather than later, and leaving the current set for the eventual SS, where they can be used more selectively.
Question: Is it possible / does it make any sort of sense to build a wheelset that essentially has disc-specific hubs etc., with a v-brake rims/hoops?
Something like Hope Pro 2 hubs - DT Swiss spokes - and Mavic XM719s?
Assuming I then make the switch, I reason I could then run the disc brakes as per normal, albeit with v-brake rims? Surely I could then simply swap out the v-brake rims for 'disc-specific' rims later?
Any opinions / suggestions would be appreciated!
a rim is a rim.. disk rims just look nicer with more room for decals etc.
had a set of avg rims on Disk XTR hubs for a long time.
worked like a rim should.
Thanks Renier...
I figured as much - but I've yet to start worrying about disc-specific terms/tech, so thought I would check.
I basically wanted to know whether a v-brake rim would 'align' with a disc-specific hub without any issues - I presume they would? 32h hub needs a 32h rim - irrespective of whether the rim is v-brake or disc-specific?
Is it that simple?
I'm building my SS this way. Same story with the frame, older v-brake frame with a new fork. thinking of milling a adapter to bolt to the frame to take the rear caliper. I have seen this done on a fisher. or the first prize would be just to have v-brakes on the back and good stop'rs on the front where you need them. even thinking a 180 disk.
Yanks call this "mullet style" - disc front, v's at the back...
I might actually end up going this route on the 'new' frame.
Unicoi might be a bit too flexy with discs at the back...
Renier is right. The rims don't care about the hubs and vice versa. What you want to do makes sense but I suggest you choose your rims very carefully. Choose rims with similar ERDs (effective rim diameter) so that when you swap over to disc-specific rims later, you can keep the same spokes.
If the ERDs differ by as much as 3mm (an depending how the rounding-off or rounding up calculations were done initially), you will have to get new spokes as well. Spokes are expensive.
This will require quite a bit of research.
very good advice!! will also keep this in mind in future! tx JB
Thanks JB - will keep all of this in mind, though I reckon it would probably be easier if I just get you to build the wheels! :P
Will probably be PM'ing you in due course!
Danger Dassie's Schwinn is set up this way. I havve a Mavic Crossride wheelset that is "dual duty".
Check again chaps.
A lot of Disc specific rims are not compatible with V-brake setups. They are painted complete. They are often oval or triangular extrusions.
Using a V-brake rim with discs is no prob however.
Putting disc specific rims on a V-brake setup will simply cost you more, unless u are going to add disc brakes later.
Hope that helps.
I wonder if those are commercially available, would be handy for cyclocross
Use Magura hydraulic rim brakes ,check CRC for really good prices .
They are definative rim brakes , used on a tandem tourer and early downhill.
The trick guys still use them ,only downside mud ,and how often do you ride in that ?
