What is the easiest way to top-up the sealant of your tubeless setup? Just deflate, pop out the bead, and pour in some more?
Yes, the way to go
Do you have to do the whole soap-and-water thing afterwards again etc?
No
Why pop out the bead and mess half of it out trying to seat the bead again? Take the valve out and refill the desired amout into the tyre, reinsert valve and inflate to desired pressure
Every 3 to 5 months I give my wheels a sealant - service. Remove the tyre, loose the old sealant, clean the rims and tyres, add new fresh sealant and off I go. The only way I get proper peace of mind. Works for me!
+1 also give the valve a good cleaning
Not all valves cores are removable
