I have a bike, currently kitted out with an assortment of older Shimano components. I am planning to upgrade from the 8spd setup to a modern 10spd configuration, but have some questions regarding compatibility.
The current bike has a Shimano 105 (RD-1050) rear derailer, 105 8spd cassette (11/23), newish (2007 vintage) Tiagra front derailer, RX 8spd shifters/brake levers, new Tiagra brake calipers, square taper BB and RSX 175mm cranks (52/42). A Shimano HG50 8spd chain completes the setup.
Am I right in thinking that my 8spd cassette is interchangeable with a new 10spd cassette (Shimano or SRAM), so that if I change the cassette, shifters, chain and rear derailer, I will have a working 10spd system? I plan to upgrade to a compact crank and BB in the next stage of the conversion, to keep costs down.
If this is feasible, would the following components be suitable?:
SRAM PG1070 cassette (12-27 or 11-25)
SRAM Rival carbon shifters
SRAM Rival rear derailer
SRAM PC1030 chain
Comments and suggestions are welcome.
a 10 speed cassette will probably not fit your existing freehub, and you probably wont get a replacement freehub that will take a 10 speed cassette = you will need a new rear hub (and at minimum a rearwheel rebuild.)
ten speed chains are narrower, and will not run or your rsx crank/chainrings. You wont get 10speed chainrings for an rsx crank = you will need a new crankset.
So it sounds as if my plan will work, even with the older crank until I upgrade that.
Thanks for the comments.
