Hi All,
Some power results from day 1 of the Cederberg MTB.
This was my first mountainbike event with a power meter and I used it extensively to pace myself over the 3 days.  My aim was not to blow up and to finish the event feeling like I could go for another couple of days.   I set my target power for 275w (about 80% of my 20min threshold) and pretty much managed to hold it there on climbs and most flats.  Descents pull down the normalised power readings.  I weigh 77kg.
It was an awesome ride- highly recommended.
Day 1 was brutal with over 4 hours in the saddle for me, terrain was very sandy and rocky and temperatures were over 35c.  The speed sensor wasnt working so distance shows 0 for the day. If I recall I finished the stage in 26th place, but the leaders were a good 30 mins up on me!
1st hour:
    Duration:      1:00:00 (1:04:36)
    Work:          837 kJ
    TSS:           61.7 (intensity factor 0.786)
    Norm Power:    267
    VI:            1.15
    Distance:      0 m
    Elevation Gain:        525 m
    Elevation Loss:       405 m
        Min    Max    Avg
    Power:           0    687    233     watts
    Heart rate:      0    175    157     bpm
    Cadence:         30    121    79     rpm
    Speed:           0    0    0.0     kph
    Pace             0:00    0:00    0:00     min/km
    Altitude:        388    639    499     m
    Crank Torque:    0    81.4    28.3     N-m
2nd hour:
    Duration:      1:00:17
    Work:          896 kJ
    TSS:           55.7 (intensity factor 0.745)
    Norm Power:    253
    VI:            1.02
    Distance:      0 m
    Elevation Gain:        622 m
    Elevation Loss:       61 m
        Min    Max    Avg
    Power:           0    760    248     watts
    Heart rate:      139    176    168     bpm
    Cadence:         51    118    76     rpm
    Speed:           0    0    0.0     kph
    Altitude:        545    1106    861     m
    Crank Torque:    0    102.2    31.7     N-m
3rd hour:
    Duration:      1:00:02 (1:07:36)
    Work:          786 kJ
    TSS:           46.1 (intensity factor 0.679)
    Norm Power:    231
    VI:            1.06
    Distance:      0 m
    Elevation Gain:        495 m
    Elevation Loss:       366 m
        Min    Max    Avg
    Power:           0    702    218     watts
    Heart rate:      138    173    163     bpm
    Cadence:         30    120    75     rpm
    Speed:           0    0    0.0     kph
    Altitude:        1097    1264    1194     m
    Crank Torque:    0    93.9    28.4     N-m
4th hour:
    Duration:      59:21 (1:15:34)
    Work:          623 kJ
    TSS:           34.4 (intensity factor 0.59)
    Norm Power:    201
    VI:            1.15
    Distance:      0 m
    Elevation Gain:        213 m
    Elevation Loss:       728 m
        Min    Max    Avg
    Power:           0    732    175     watts
    Heart rate:      0    171    156     bpm
    Cadence:         28    119    76     rpm
    Speed:           0    0    0.0     kph
    Altitude:        712    1262    1088     m
    Crank Torque:    0    116.6    22.8     N-m
Entire workout (218 watts):
    Duration:      4:00:23 (5:27:19)
    Work:          3145 kJ
    TSS:           203.2 (intensity factor 0.712)
    Norm Power:    242
    VI:            1.11
    Distance:      0 m
    Elevation Gain:        1860 m
    Elevation Loss:       2282 m
        Min    Max    Avg
    Power:           0    760    218     watts
    Heart rate:      0    176    161     bpm
    Cadence:         28    121    76     rpm
    Speed:           0    0    0.0     kph
    Altitude:        388    1264    908     m
    Crank Torque:    0    116.6    27.8     N-m
Peak 5s (590 watts):
    Duration:      0:05
    Work:          3 kJ
    TSS:           n/a
    Norm Power:    n/a
    VI:            n/a
    Distance:      0 m
    Elevation Gain:        0 m
    Elevation Loss:       0 m
        Min    Max    Avg
    Power:           516    687    590     watts
    Heart rate:      102    113    108     bpm
    Cadence:         81    97    92     rpm
    Speed:           0    0    0.0     kph
    Altitude:        426    426    426     m
    Crank Torque:    53.4    80.9    61.7     N-m
Peak 5min (301 watts):
    Duration:      5:00
    Work:          90 kJ
    TSS:           6.6 (intensity factor 0.892)
    Norm Power:    303
    VI:            1.01
    Distance:      0 m
    Elevation Gain:        73 m
    Elevation Loss:       0 m
        Min    Max    Avg
    Power:           75    444    301     watts
    Heart rate:      159    172    168     bpm
    Cadence:         68    97    79     rpm
    Speed:           0    0    0.0     kph
    Altitude:        413    486    450     m
    Crank Torque:    9.5    52.3    36.6     N-m
Peak 10min (289 watts):
    Duration:      10:00 (10:19)
    Work:          173 kJ
    TSS:           12.2 (intensity factor 0.856)
    Norm Power:    291
    VI:            1.01
    Distance:      0 m
    Elevation Gain:        136 m
    Elevation Loss:       5 m
        Min    Max    Avg
    Power:           0    516    289     watts
    Heart rate:      147    172    168     bpm
    Cadence:         43    111    79     rpm
    Speed:           0    0    0.0     kph
    Altitude:        412    543    472     m
    Crank Torque:    0    73.1    35.2     N-m
Peak 20min (279 watts):
    Duration:      20:00
    Work:          335 kJ
    TSS:           22.8 (intensity factor 0.827)
    Norm Power:    281
    VI:            1.01
    Distance:      0 m
    Elevation Gain:        263 m
    Elevation Loss:       5 m
        Min    Max    Avg
    Power:           0    516    279     watts
    Heart rate:      147    175    170     bpm
    Cadence:         53    111    79     rpm
    Speed:           0    0    0.0     kph
    Altitude:        412    670    539     m
    Crank Torque:    0    73.1    34.1     N-m
Peak 60min (259 watts):
    Duration:      1:00:00 (1:00:40)
    Work:          931 kJ
    TSS:           62.4 (intensity factor 0.79)
    Norm Power:    269
    VI:            1.04
    Distance:      0 m
    Elevation Gain:        645 m
    Elevation Loss:       190 m
        Min    Max    Avg
    Power:           0    674    259     watts
    Heart rate:      142    176    169     bpm
    Cadence:         31    119    78     rpm
    Speed:           0    0    0.0     kph
    Altitude:        410    963    653     m
    Crank Torque:    0    102.2    32.2     N-m
  • Replies 32
An Ergomo pro.
I had to shave down the bb on my MTB from 73mm to 68mm and then I use the same computer as on my road bike.  I am sure that if it coped with Cederberg, it will handle anything fine.
Will have to look into it. Heard alot about the Ergomo Pro and that is probably the product to go for. Using a power meter is definately the best way to go...
An Ergomo pro.
I had to shave down the bb on my MTB from 73mm to 68mm and then I use the same computer as on my road bike.  I am sure that if it coped with Cederberg' date=' it will handle anything fine.
There is an MTB version of the Ergomo, that is wider than the road version.  Which one are you using?
I see that the VI is quite low, so it is a pretty constant effort - similar to a time-trial.  Wide range of cadence/torque though.
On day 1 there was very little free wheeling hence the narrow gap between avg power and normalised power.
I think MTB races will always tend to give a wide cadence range due to the variabiulity of the terrain and the fact that one can seldom get into a steady rythm.
I see that the VI is quite low' date=' so it is a pretty constant effort - similar to a time-trial.  Wide range of cadence/torque though.[/quote']
I am using the MTB Ergomo- but it only fits a 68mm bb and the Yeti was a 73, hence he surgery.
Whats VI ? I have never really looked at it before ?
I rode the stage exactly like a time trial- the power chart have very long periods where it looks almost flat at 265w-275w.
Cadence/torque variability is, I think the biggest difference between road and mtbing. Generally caused by terrain changes.
VI = Variability Index = Normalised Power/Average Power
Normalised power takes into account the fact that the physiological demand of riding at intensities above threshold is far greater than riding below threshold.  So, if you have a highly variable ride i.e. regular anaerobic bouts, your normalised power will be much higher than your average power and hence VI will be quite a bit bigger than 1.  Normalised power is the equivalent steady state (consistent) power that you would have to produce to achieve the same physiological cost.
A timetrial is typically a very evenly paced effort, hence VI would be close to 1.  But, in a road TT cadence variation would be very small, and gears would be used to keep the power output and cadence in a narrow range.  Looking at your numbers, there is a huge cadence variance.
The wide range of gears on an MTB would enable this.
You mention riding at 275w as 80% of 20 min power - this would make 20 min power ~340w. In your stats however it appears that you have got FTP set at 340w ?
If 20 min power is 340w then it is unlikely that FTP is also 340w - you might want to have a look at this to make sure your levels are right. (Unless you meant 340 was your FTP and not 20 min power)
BTW - The Power Tap disc compatible MTB hub is now getting close to a release date for those that might be looking at power on an MTB.
Wow, that would be awsome to have a Mtb PowerTap!! But come to think of it, I don't use disc's on my Mtb so I guess the normal road PT would be fine? That said, DanNeal said something about the PT having a problem with shock absorbing and loss of date.
BikeMax I think 1kTT wanted to do a Tempo ride / L3 for the race which makes since to me since I'll do the same. But it does look like he lost some power during the last hour so this might have been a High L3 and should rather aid for a mid L3 the first 3hours and then gun it a bit harder during the last hour, this works for me but every one has there own why of using there energy.
That's great news about the powertap for disc wheels.
Looking at 1kTT's stats, it appears that he was riding in mid L2 to mid L3 for the stage. Adapting the figures to my weight (I did a similar time for the stage), I reckon that I was riding mid to high L3 for the stage (on average) with no significant periods at L4.
I felt like I was at my limit for the whole stage and finished with an average HR of 90%. I think this really emphasises how important sweetspot  training is for marathon length MTB races.
But it does look like he lost some power during the last hour so this might have been a High L3 and should rather aid for a mid L3 the first 3hours and then gun it a bit harder during the last hour' date=' this works for me but every one has there own why of using there energy.
The last hour had quite a bit of downhill and technical stuff which would have lowered the power. But I also think a lot of us were cramping real bad then as well! It was about 40 deg at that point!
Jason, silly me, forgot about the downhills and technical parts were you can't really padel:-P I wanted a PowerMeter for my Mtb for a long time already, I think you really need to pace yourself perfectly if you want to be strong till the end and a Power Meter would really help big time!
Looking at 1kTT's stats' date=' it appears that he was riding in mid L2 to mid L3 for the stage. Adapting the figures to my weight (I did a similar time for the stage), I reckon that I was riding mid to high L3 for the stage (on average) with no significant periods at L4.
Hi Jason
It would be possible for you to be riding at this intensity for this duration if you were going full gas and not worrying aout the next few days - but if this was how you were riding then I would have expected to see you into the L4 zone on the climbs.
If you did a similar time then you might want to look at how economically you rode the stage if it cost you that much more energy ?
But yes - SST for most any races is a great way to build aerobic fitness and absolutely essential for this type of race as you say.
Wow' date=' that would be awsome to have a Mtb PowerTap!! But come to think of it, I don't use disc's on my Mtb so I guess the normal road PT would be fine? That said, DanNeal said something about the PT having a problem with shock absorbing and loss of date.
We have seen pretty good results on the MT bikes we have installed PT hubs to - no issues with vibration or data loss or mositure.
The data is very different and very interesting and can certainly demonstrate the diffeent requirements of racing MTB vs Road.
