So I did a tubeless conversion on an Alex DP17 rim using stans yellow tape and a Bontrager screw in schrader valve. I'm having an issue with the valve leaking because at first the end was too wide and thus didn't fit flush on the inside of the rim, so the geniuses who installed it filed the edges but now it cuts through the rubber still and still leaks...
Anyone know of any other manufacturer who makes a bigger valve to lock into a schrader valve rim hole?
Shot a lot
well there are quite a few actually, schwalbe make quite a nice one the one which I am using, other then that i know american classic make one and there are one or two others, I see your in jozi so give solomons a call and and if they are too far to drive to i know you can arrange to have them post stuff to you, just ask for a photo of the tubeless valves they sell and hey presto you can choose which ever one will suit your needs best
their site is www.solomons.co.za contact details are on there somewhere
Had the same problem - i.e. could not find Schrader valve.
Went to motorcycle/scooter service shop and asked for an old tyre.
Then cut out the valve (got o-rings from local hardware store)
