i have a new set of wheels with a different cassette size.
the difference in ratios is minor - the current wheels / setup has a 12-25 and the new wheels have a 11-25- if i want to use them, is it just a matter of swopping the wheels? or do i need to make adjustments to the rear derailer?
any advice would be appreciated before i try them out / risk damaging the drivetrain?
cheers
cheers
Go for it as Andre says but...
The wheel dishing may be a few mm's different so you may need to reset your gear cable tension.
Also check your limit screws the first time you do it - in worst case scenario your chain could come off the inside of the cassette, get jammed between the cassette/spokes and cause some nasty damage.
Best idea is once you've done the change run the gears on your bike stand for a while and manually try to get the chain off the cassette at the back - if it doesn't come off you should be safe...
