Compared the 2 frames earlier in the week. On the French website they had the frame weights. The ISP is about 500g lighter, which I thought was a lot. Not 100% sure if the TCR weight excl the seatpost weight, but if you add the weight of the seatpost - then the difference will be about 800g.
This is quite significant!!
That is possible on the 2012 frames since the tcr advanced now has an alu steerer I believe as previously commented. I think on the 2011 frame the difference is way less, unless they give the weight without the seatpost which is likely.
Check out some prices @ Cycle Factory
GIANT 2012TCR ADV 1 SL ISP R52,000 (Dura Ace)
TCR ADV 0 R47,138 (Ultegra Di2)TCR ADV 2 R27,300 (Ultegra)
the ultegra Di2 is something new to me ... probably only small saving in weight.
i have contacted them before via mail and pm but never received a reply. will try again to get some info on the 2012 frames. i will post information here should i receive any info.
Edited by smerds
