TheLee Posted September 30, 2011 Posted September 30, 2011 I would love some more info on this! The floor is open!
mark ellis Posted September 30, 2011 Posted September 30, 2011 only on Tuesdays before the sun comes up! What is plyometrics?
The Drongo Posted September 30, 2011 Posted September 30, 2011 Only off a bridge if you have a string attached.
ricochet_rabbit Posted September 30, 2011 Posted September 30, 2011 Plyometric exercises, essentially most of those exercises you did as a kid at football or rugby practice, will benefit you in some way. The exercises would assist in keeping a better balance between cycling and non-cycling muscles thus reducing injuries. Doing the right exercises would also help strengthen the core, glutes & hip flexors.
Grebel Posted September 30, 2011 Posted September 30, 2011 I wouldn't recommend it without a dropper post...
Gravity Posted December 12, 2011 Posted December 12, 2011 try doing something called the "deck squat" for even more painful legs in the morning finish off with an explosive jump.
HowellingWulf Posted December 12, 2011 Posted December 12, 2011 Only into the pool when there is water in it and provided the water is of a pleasant temperature. Can you illustrate plyometrics with some pictures/diagrams please.
HowellingWulf Posted December 12, 2011 Posted December 12, 2011 try doing something called the "deck squat" for even more painful legs in the morning finish off with an explosive jump. Is that the same as the willeaapdans?
Tiny K Posted December 12, 2011 Posted December 12, 2011 Is that the same as the willeaapdans? Don't you mean seks?
Register a new accountSign in
