Hi
I am looking at getting some hubs, for standard 9mm QR. Just want some info on what the technical difference is between the Chris King Classic Hub (http://www.chainreactioncycles.com/Models.aspx?ModelID=2612) and the Chris King ISO Hub (http://www.chainreactioncycles.com/Models.aspx?ModelID=2039) ?
Is the ISO some other/older/proprietary type system? All I want to establish is whether I should use the classic or the ISO hub in my decision making, comparing process. I don't want to buy something I can't technically use in the end. The other hubs I am considering are the Hope Pro II's, which I know will work.
Thanks for the enlightment
Classic hubs are not for discs.
Ah, yes, I think you're right. Won't be able to run disc brakes on them. So I would have to look at the ISO disc one's then.
