Can I run a Sram 10sp chain with a Campag 10 sp drive train? I am sure you can, but just want to make sure.
But why risk the wrath of the Campagnolo gods? ;)
I have used a new model 105 chain on a Record 10sp group without any problems. The pin spacing is the same (0.5") for all chains. The plate width is what varies - it's 5.9mm for Campag and 5.88mm for Shimano 10sp (or the other way round). It gets narrower for 11sp chains.
I reckon you'll be fine using a SRAM chain, though the chain will likely wear a lot faster than a Shimano or Campag chain (due to the chain, not the setup):
https://community.bikehub.co.za/topic/111338-chain-comparison/
