I have moved my XT rear derailleur to my wifes bike and cannot get it to operate properly.
It changes up and down perfectly in all gears.
It is a new XT cluster,chain and pulleys.
Under load the donnerse ding keeps snagging forward when not even changing gear.
Is it a factor of chain length that is not right or is it something simple
It is a F.S Trek
help before my wife donners me!!!
Search vir 'n vorige post waar mnr Boreman beskryf het wat die angles van die derraileur moet wees tov korrekte ketting lengte. Die ou wat die vraag gestel het het dieselfde probleem as jy gehad.
Sit jou helmet op dit help as sy begin slaan.
Not a very helpful lot this morning' date='are we?[/quote']
We can't help if we can't understand the problem. Perhaps if you describe things more accurately we can help. Leave out the bits about what make of chain, bike and RD you have on there. They're all the same when it comes to troubleshooting.
Not a very helpful lot this morning' date='are we?[/quote']Usually get better response if you post tech questions in the Tech Q & A forum. Johan lives in there... Big%20smile
Perhaps try to explain the above description in a more explanotory way?
 I thought I had explained it pretty accurately(minus a few choice words of course)
Vot I meen is,when under load(FS)the reaar DR jerks forward as if there is a probleemsh with the chain length.
However,we have discovered that the middle chain ring is fooked.
Soooo.Replaced it this morning...alles is reg.. so the NYD ride up Ou Wa Pad to watch the sunrise is happening.
Vot I meen is' date='when under load(FS)the reaar DR jerks forward as if there is a probleemsh with the chain length.
Aaah... I see the mirrel chainring was being a Jerk .... Well done at least the wife can now pedal without being snagged.
Enjoy the sunrise!
