How do you determine what cage length your rear derailleur should be? I'm running 22/32/44 front and 11-32 rear. Shimano SLX or XT rear Derailleur.
This is how I understand it: chainwrap capacity = big ring - small ring + big cog - small cog
I have 38-34 rings and an 11-36 cassette
so, 38-24+36-11 = 39t
SGS = long cage has a 43t capacity
GS = med cage has a 35t capacity
So I got a long cage rear derailleur.
keep in mind that whether you're dual sus or hard tail can also impact the choice, with regards to extra chain length needed as suspension compresses.
that's how I worked it out as well, but apparently a shorter cage will shift better, only thing is you won't be able to go big front to big rear or small to small. But you shouldn't be doing that anyway. So I'm quite keen to try the shorter cage to improve shifting.
i'm on a ds.
Triple blade: Long cage
2 Blade: Medium cage
1 blade: short cage
Found this great topic on another site and can't see it being discussed on this form before. Maybe it was before my time. This is not my facts but like to read what you guys have to say.
Question
What is the proper application for long versus short cage derailleur? Will the short one work with a 11/34 cassette? Does it matter if the bike has a rear suspension or a hardtail?
Quick answer: The medium cage will work, but you'll drop your chain if you accidentally shift to the small-small combo. Suspension *could* be a factor, depending on how much "chainstay growth" your frame experiences as your suspension cycles.
Long answer:
Derailleurs have a rated capacity. This is their ability to take up excess chain. After all, you need just about all of your chain to run in the big-big combo, whereas you have a bunch of extra links doing nothing when you run in your small-small combo.
Not that either of those cross-chain combos are normal to run in, but let me get to that in a minute.
Manufacturer stated derailleur capacities are as follows:
Shimano long = 45T; medium = 33T
SRAM long = 43T; medium = 37T; short = 30T
Speaking from experience, Shimano is a bit conservative in their capacity rating. I can only assume the same is true of SRAM (I'll get to that, too).
The easy capacity formula is to add your big ring & cog sizes, then subtract your small ring and cog sizes. It looks like this:
cap req'd (T) = (BIG ring - small ring) + (BIG cog - small cog)
...so for a typical 44-32-22 mountain crank & 11-34 cassette...
T = (44T - 22T) + (34T - 11T)
.. = (22T) + (23T)
.. = 45T
Using this simple forumla, you would need a derailleur with a 45T rated capacity to absorb all the possible extra links of a typical 27-speed drivetrain.
(I make the assumption SRAM stated capacity is conservative, since they list 43T as the long cage capacity -- 2T short of what is required by this forumla).
Where do shorter cage lengths come into play? Right here!
Even though the long cage will, in theory, take you down to the 22x11 gear combo and hold adequate chain tension, let's be logical: 22x11 is a combo you don't use!
Rather than use the generic formula, let's map out the capacity for each gear combination (based off of a Shimano cog pattern; SRAM will be slightly different):
http://www.booboodog.net/images/derailleur-capacity.gif
44x34 starts off at zero because in that combo, all of the chain is being used up by the ring and cog, and the derailleur needs to take up none of it. As you shift through the cassette range (moving down the column), the amount of free chain increases as the cog size decreases.
Take a look at the useable gears, which I've outlined in green and yellow. Those fall near the stated capacity of the medium cage derailleurs. (I mentioned that Shimano's stated capacity is conservative, and in practice, I find their medium cage to be closer to 39T.)
For instance, in the middle ring (32) and the small cog (11), the table shows you've got to absorb 35T. This is near the stated capacity of either of the medium cagederailleurs. This gear combo remains useable, but you'd be better off shifting to your big ring for better chain tension.
You can also see that to use a SRAM short cage derailleur (30T capacity) on this drivetrain would leave you with two or three unusable gears while in the middle ring, and only about three useablegears from your granny ring. (Any number greater than 30T on the table would be near the limits of the short cage derailleur.)
Oops! Accidentally shifted into the unusable "red zone"? Nothing major: the derailleur cage folds back on itself, the chain droops, and you maybe drop the chain if you don't catch it in time.
In my opinion, it'd be stupid to size a chain any smaller than what is required to shift into big-big. If you accidentally force a shift into that combo, which is certainly possible when you're tired or "in the moment", you don't want to break anything. So chain length will be the same no matter what derailleur you choose.
http://www.booboodog.net/images/chainlength.jpg
Benefits of a shorter cage length?
- snappier shifts
- better chain tension
- less chain slap / greatly decreased drivetrain noise (!)
- better obstruction clearance / improved spoke clearance.
- slight weight loss -- but you gotta be a real weight weenie to appreciate this one.
