Which 650b Fork
2 members have voted
  1. 1. fork for a 650b bike, for Trail and XC
    • Fox 34 Talas
      1
    • Fox 34 Float
      1
    • Revelation XX
      0
    • Revelation RLT
      1
    • Revelation RCT3
      0
    • Revelation RL
      0
Hi all
Ok, so it seems in the 650 Market there are 2 set of 650b compatible forks atm.
Fox with the 34 Talas & 34 Float.
I like the idea of the Fox range with the CTD capabilities, allows me to ride it which every I need for where, locked down to say 110/120 for XC and full open when doing up down trail stuff.
& then
Rock Shox with the Revelation range:
Revelation XX - Only tapered on that I could see.
Revelation RCT3
Revelation RL
Revelation RLT
Anyone willing to throw some comment in on the Revelation, I got a SID (RLT on my 26er atm, and well I like it, but then don't have allot of previous experience to compare it against).
In the Rock Shox range Solo air and Dual air, Whats the difference/benefit.
And because of previous experience lets add a poll, pick which fork you'd select for trail/xc riding
G
Edited by awesme
Fox: Float is not adjustable, TALAS is (Travel adjustable liniar air spring - or something like that)
Rock Shox: As far as I know the 2013 models also just has a single air setting, no more positive and negative air setting, it does that by its self. All the settings on the RS is a bit useless, just go for the RLT version.
Both the Relevation and Fox 34 range are the beefed up forks, more for trail riding etc. Fox is usually a bit more heavier than Rock Shox.
Hi there
thanks.
Fox, nice to know the definition of the name Talas :)
Ye, read last night, only the Solo air, and it is adjusted using a spring, depending on the length required/desired. So for RS you'd propose the Revelation RLT.
G
On the RS, whats the difference / benefits going with the RLT compared to the XX (which is a tapered fork).
G
bassasdaindia
So far it looks like the 650b will only work/covered under the the Revelation range.
G
quote name='bassasdaindia' timestamp='1347805339' post='1781982']
rock shox Reba and Sid are on the way
