American classic 15mm adapter issue
DubbelBuys
Hello tech hubbers,
I've recently bought an AM Classic wheelset with the 15mm thru axle converter, but when the converter is installed I have the following problems:
1. The converter only has 1 hex nut to tighten :eek:
2. When the converter hex nut is installed (on the wheel) & hand tightened & the round "lock nut" is installed & turned all the way in there's a gap between the hex nut & the 'lock nut'.
See pic for detail (this is the same scenario / distance as when installed, but obviously easier to see when not installed)
Thanx in advance
Link to comment
Share on other sites
Hello tech hubbers,
Thanx in advance
Dont worry, mines the same. Thats how they are.
just nip the hex nut so its snug... not tight!!! and put the round threaded cap on.
Link to comment
but if there's space between the hex nut & round end cap then the hex nut will looen over time, won't it?
Should I try to find a washer to take up the space btween the hex & end cap/nut?
Link to comment
It fine, dont put a washer in there. just do as it says in fig. 6 and 7.
it doesnt come loose. mines been fone for ages.
Link to comment
Cool - Still doesn't seem right though from a technical point of view, but hey whoami to complain? If it works it works!
Thanx
Link to comment
