Newbie question - disc brakes
ChantelM
Forgive me if this is a stupid question, but I'm a newbie to mountain biking.
I purchased a Silverback without disc brakes before I knew anything. I've seen comments where people suggest definitely getting a bike with disc brakes, so I was wondering if it is possible to add disc brakes to a bike that doesn't have?
Link to comment
Share on other sites
If the bike you have is fitted "for, but not with" you can. Check if there are mounting lugs on the left fork leg and chainstay.
Link to comment
Guest Omega Man
And that the hubs can take rotors.
Link to comment
It looks like it has on the back but not on the front, I'm not sure. See pics.
It's a 2013 Silverback Stride20
Edited by ChantelM
Link to comment
It looks like it does on the back but not on the front, I'm not sure. See pics.
Which bike is it?
it's a 2013 Silverback Stride20
Link to comment
Show us a pic of the other side of the front fork, or what type of ork is it? You will also need new hubs that are disk compatible and spokes to rebuild your wheel or even look at a new wheelset.
Link to comment
Very expensive upgrade in relation to the bike which you will most probably want to upgrade if you get into it. Well set up v brakes works well. Dont stress about your gear, get pedalling and learn to ride as well as what all the bits n pieces on your bike do. Just have fun and save your money for your next bike.
Link to comment
Thanks. Why are disc brakes better than the v brakes?
Link to comment
It seems that you may need a new fork as well. Stay with your V-brakes untill you really feel the need to upgrade. Keep them well adjusted and use good quality brake pads.
Link to comment
No real reason for anyone starting out but dome benefits:
Braking surface not affected by buckled rim
Rims can be lighter
Better in wet
Further from mud collection in extreme wet
Hydraulic hose requires less maintenance
Closed system
Hydraulic feel, lighter braking
Link to comment
V-brakes are just fine. They require a bit of cable maintenance from time to time but they are still excellent brakes.
If you upgrade the pads to Koolstop (salmon colour) (from the US, buy from www.harriscyclery.com) you'll have really excellent braking with long rim and pad life.
Link to comment
